The SD card does not mount at startup
Hello, everyone! When I discovered this project, I absolutely wanted to make ESPuinos for my two boys, ages 2 and 4. It’s really a great project!
  1. I ordered the following supplies from AliExpress:
  • LOLIN D32 Pro V2.0.0 - WiFi & Bluetooth board based on ESP-32, ESP32, 16 MB, 8 MB FLASH, PSRAM, MicroPython
  • PCM5102A DAC Decoder GY-PCM5102, I2S Player Module, pHAT Board, PCM5102 Digital Audio Board, I2S Interface for Raspberry Pi
  • AUIN 2-pack 40 mm full-range speakers, 4 Ohm, 5W, 1.5 inches, 16-core, rubber surround, NdFeB magnet, aluminum cap, waterproof, for DIY Bluetooth speakers
  • 8406 PAM8406 Interference-Free Class D Stereo Audio Power Amplifier Module Development Board
  • RC522 RFID NFC Module
  • Individually addressable WS2812B LED pixel ring, 12-bit, WS2812, integrated circuit, multicolor circle, DC 5V light modules
  • KY-040 Rotary Encoder Module
  • A few push buttons
  1. I made the following connections on the breadboard (see diagram) :
  2. I downloaded the pre-compiled Master/lolin_d32_pro firmware from here: ESPuino-Firmware/Firmwares/master/lolin_d32_pro at main · biologist79/ESPuino-Firmware · GitHub
    The files:
  • bootloader.bin
  • partitions.bin
  • firmware-FR.bin
I uploaded it to the board using the following command: ~/.platformio/penv/bin/python -m esptool --chip esp32 --port /dev/cu.usbserial-110 --baud 460800 write_flash 0x1000 bootloader.bin 0x8000 partitions.bin 0x10000 firmware-FR.bin
I inserted a 64GB SD card formatted as FAT-32
And… it starts up—the LEDs turn orange, then red, then they turn off, and… nothing happens. No ESPUINO Wi-Fi network. I launched the serial monitor with this command:
screen /dev/cu.usbserial-110 115200
and I get:
E (16246) vfs_fat_sdmmc: sdmmc_card_init failed (0x109).
E [16256] Impossible de monter la carte SD.
E (16758) sdmmc_io: sdmmc_io_reset: unexpected return: 0x108
E (16758) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
E [16768] Impossible de monter la carte SD.
E (17270) sdmmc_io: sdmmc_io_reset: unexpected return: 0x108
E (17270) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
E [17280] Impossible de monter la carte SD.
E (17782) sdmmc_io: sdmmc_io_reset: unexpected return: 0x108
E (17782) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
E [17792] Impossible de monter la carte SD.
E (18294) sdmmc_io: sdmmc_io_reset: unexpected return: 0x108
E (18294) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
E [18304] Impossible de monter la carte SD.
E (18806) sdmmc_io: sdmmc_io_reset: unexpected return: 0x108
E (18806) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
E [18816] Impossible de monter la carte SD.
E (19318) sdmmc_io: sdmmc_io_reset: unexpected return: 0x108
E (19319) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
E [19328] Impossible de monter la carte SD.
E (19851) sdmmc_sd: sdmmc_init_sd_if_cond: send_if_cond (1) returned 0x109
E (19851) vfs_fat_sdmmc: sdmmc_card_init failed (0x109).
E [19861] Impossible de monter la carte SD.
E [20372] Échec du démarrage en raison de la carte SD. Va passer en mode veille profonde…
N [20372] shutdown LED..
Can you help me? Thanks in advance!
  1. According to your schematics there’s no 2nd sd card slot while logfile shows sdmmc is used. SD card slot onboard on Lolin D32 pro is SPI only and cannot be used for sdmmc. You need to custom compile a firmware for SD via SPI. However, it’s not really tested if it’s (SD-SPI) still working (just to be honest).
  2. Did you format the sd card with fat32?
Hello,
Thank you for your quick response. Yes, I did format the card as FAT32. I’m currently trying to compile the code using VS Code and PioArduino. Could you advise me on what changes I need to make in settings.h and settings_lolin_d32_pro.h?
Thanks in advance!
When I try to compile, it stops and I get the following error:
*** [.pio\build\lolin_d32_pro\firmware.elf] ModuleNotFoundError : No module named 'SCons.Tool.FortranCommon'
Here is the entire console output:
 Executing task: C:\Users\brisfan\.platformio\penv\Scripts\platformio.exe run --environment lolin_d32_pro
Processing lolin_d32_pro (board: lolin_d32_pro; platform: https://github.com/pioarduino/platform-espressif32/releases/download/55.03.311/platform-espressif32.zip; framework: arduino, espidf)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing https://github.com/pioarduino/registry/releases/download/0.0.1/scons-4.8.1.zip
Unpacking  [####################################]  100%
Tool Manager: tool-scons@4.40801.0 has been installed!
Tool Manager: Installing https://github.com/pioarduino/scons/releases/download/4.11.1/scons-local-4.11.1.tar.gz
Tool Manager: tool-scons@4.41101.0 has been installed!
Verbose mode can be enabled via `-v, --verbose` option
  "b157ba4" (branch "master", revision "20260919-DEV") -> C:\Users\brisfan\iCloudDrive\Documents\ESPuino\.pio\build\lolin_d32_pro\generated\gitrevision.h
GENERATING PLATFORM INFO HEADER FILE
  platform="lolin_d32_pro" customBuild=False -> C:\Users\brisfan\iCloudDrive\Documents\ESPuino\.pio\build\lolin_d32_pro\generated\platforminfo.h
--- GENERATING HTML BINARY HEADERS -> C:\Users\brisfan\iCloudDrive\Documents\ESPuino\.pio\build\lolin_d32_pro\generated ---
  Encoding: management.html
  Encoding: accesspoint.html
  Encoding: js/i18next.min.js
  Encoding: js/i18nextHttpBackend.min.js
  Encoding: REST_API.yaml
  Encoding: swagger.html
  Encoding: js/swaggerInitializer.js
  Encoding: js/loc_i18next.min.js
  Encoding: locales/de.json
  Encoding: locales/en.json
  Encoding: locales/fr.json
  Encoding: vendor/bootstrap/bootstrap.min.css
  Encoding: vendor/bootstrap/bootstrap.bundle.min.js
  Encoding: vendor/jquery/jquery.min.js
  Encoding: vendor/jqueryui/jquery-ui.min.js
  Encoding: vendor/jstree/jstree.min.js
  Encoding: vendor/jstree/light/style.min.css
  Encoding: vendor/jstree/light/32px.png
  Encoding: vendor/jstree/light/40px.png
  Encoding: vendor/jstree/light/throbber.gif
  Encoding: vendor/jstree/dark/style.min.css
  Encoding: vendor/jstree/dark/32px.png
  Encoding: vendor/jstree/dark/40px.png
  Encoding: vendor/jstree/dark/throbber.gif
  Encoding: vendor/fontawesome/css/all.min.css
  Encoding: vendor/fontawesome/webfonts/fa-solid-900.woff2
  Encoding: vendor/fontawesome/webfonts/fa-regular-400.woff2
  Encoding: vendor/fontawesome/webfonts/fa-brands-400.woff2
  Encoding: vendor/bootstrap-slider/bootstrap-slider.min.css
  Encoding: vendor/bootstrap-slider/bootstrap-slider.min.js
  Encoding: vendor/i18next/i18next.min.js
  Encoding: vendor/i18next/i18nextHttpBackend.min.js
  Encoding: vendor/i18next/loc-i18next.min.js
  Encoding: vendor/natsort/natcompare.js
  Encoding: vendor/branding/logo.webp
  Encoding: vendor/branding/favicon.ico
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/lolin_d32_pro.html
PLATFORM: Espressif 32 (55.3.311) > WEMOS LOLIN D32 PRO
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, esp-prog-2, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
 - contrib-piohome @ 3.4.4
 - framework-arduinoespressif32 @ 3.3.11
 - framework-arduinoespressif32-libs @ 5.5.5+sha.b774170ff46
 - framework-espidf @ 3.50505.0 (5.5.5)
 - tool-cmake @ 4.0.3
 - tool-esp-rom-elfs @ 2024.10.11
 - tool-esptoolpy @ 5.3.0
 - tool-ninja @ 1.13.1
 - tool-xtensa-esp-elf-gdb @ 17.1.0+20260402
 - toolchain-xtensa-esp-elf @ 14.2.0+20260121
Using Python 3.13.13 environment at: C:\Users\brisfan\.platformio\penv\.espidf-5.5.5
Reading CMake configuration...
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Found 60 compatible libraries
Scanning dependencies...
Dependency Graph
|-- ESP32-audioI2S @ 4.0.0+sha.a775ccb
|-- ESP32Encoder @ 0.11.8+sha.7501cb4
|-- ESP-FTP-Server-Lib @ 0.14.1+sha.517a2c9
|-- FastLED @ 3.10.3+sha.20667c3
|-- ESPAsyncWebServer @ 3.11.1+sha.d6aa7da
|-- ArduinoJson @ 7.4.3+sha.77771d3
|-- audio-tools @ 1.2.4+sha.b4b32dc
|-- ESP32-A2DP @ 1.8.11+sha.b6da474
|-- IRremote @ 4.7.1+sha.498dc59
|-- MFRC522_I2C @ 1.0.0+sha.3cabf22
|-- MFRC522 @ 1.4.11+sha.caa3e6d
|-- LogRingBuffer @ 0.0.0+20261029095516.sha.89d7d3e
|-- PN5180 Library @ 2.2.0+sha.2479510
|-- natsort @ 0.0.0+20261029095521.sha.ebbf660
|-- ESP_I2S @ 3.3.11
|-- WiFi @ 3.3.11
|-- HTTPClient @ 3.3.11
|-- Wire @ 3.3.11
|-- SPI @ 3.3.11
|-- Update @ 3.3.11
|-- DNSServer @ 3.3.11
|-- ESPmDNS @ 3.3.11
|-- SD @ 3.3.11
|-- SD_MMC @ 3.3.11
|-- Preferences @ 3.3.11
|-- FS @ 3.3.11
Building in release mode
====================================================================================================================================================================================== [FAILED] Took 24.25 seconds ======================================================================================================================================================================================
Environment    Status    Duration
lolin_d32_pro  FAILED    00:00:24.246
================================================================================================================================================================================= 1 failed, 0 succeeded in 00:00:24.246 =================================================================================================================================================================================
 *  The terminal process "C:\Users\brisfan\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'lolin_d32_pro'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
This is a problem introduced (afaik) with platformio 6.1.20. You need to downgrade to 6.1.19 in order to make this working (again). Platformio makes use of Pyton’s virtual environment (venv) which lives in ~/.platformio. You need to „step into“ this venv:
source .platformio/penv/bin/activate
and then do the downgrade.
Inside of this venv run:
pip install "pioarduino==6.1.19"
However, Platformio did reinstall on my platform the newer version on and on. Finally I disabled Platformio as plugin; only Pioarduino is running. Now it seems to be fine.
Additionaly you need to make sure, you actually compile firmware for settings_lolin_d32_pro. Have a look at the bottom of VSC’s window. There’s something like env: <xx> (ESPuino) while <xx> should carry lolin_d32_pro. If not => change accordingly.
Good news! I downgraded pioarduino by following your instructions.
I activated the PlatformIO virtual environment with the command:
& “$env:USERPROFILE.platformio\penv\Scripts\Activate.ps1”
Then I downgraded pioarduino with:
pip install “pioarduino==6.1.19”
And the compilation works! I’m really happy—the lolin_D32_pro boots up. I was able to connect it to my home Wi-Fi and test playing music files. The sound quality is great!
Now I’m facing two issues that are holding me back from moving forward with the project. I’d really appreciate some more help if you’re willing to offer it.
Problem #1: When I turn the rotary encoder, it changes the brightness of the Neopixel LEDs instead of adjusting the volume.
Problem #2: When I connect an 18650 battery (PKCELL ICR18650 2200mAh 3.7V) to the battery port on the Lolin_D32_pro, the DAC and RFID reader LEDs light up, but the Lolin doesn’t boot up.
  • The 3.3V is normal, but the 5V is at 0.3V.
  • I connected a lab power supply set to 3.8V to the battery port, and the same thing happens, with a current draw of 0.060A and transient peaks of 0.150A.
  • However, when the lab power supply is set to 5V 1A and connected to the USB pin and the GND pin, the board powers on correctly.
Here are my settings.h and settings_lolin_d32_pro.h files
// clang-format off
        #include "Arduino.h"
        #include "values.h"
#else
	If in doubts (your board is not listed) use HAL 7
	!!!Only ESP32 with PSRAM are supported!!!
	HAL 4: Wemos Lolin D32 pro                  => settings-lolin_D32_pro.h
	HAL 5: Lilygo T8 (V1.7)                     => settings-ttgo_t8.h
	HAL 6: ESPuino complete                     => settings-complete.h
	HAL 7: Lolin D32 pro SDMMC Port-Expander    => settings-lolin_d32_pro_sdmmc_pe.h
	HAL 99: custom                              => settings-custom.h
	#ifndef HAL             // Will be set by platformio.ini. There's no need to adjust this manually right here
		#define HAL 4
	// Enforce port expander for some HALs because it's mandatory for those and users constantly forget it. Endless story...
	#if (HAL == 6) || (HAL == 7)
		#define PORT_EXPANDER_ENABLE
	//#define PORT_EXPANDER_ENABLE          // When enabled, buttons can be connected via port-expander PCA9555 (https://forum.espuino.de/t/einsatz-des-port-expanders-pca9555/306)
	#define MQTT_ENABLE                     // Make sure to configure mqtt-server and (optionally) username+pwd
	#define LANGUAGE FR                     // DE = deutsch; EN = english: FR = french
	#define HEADPHONE_ADJUST_ENABLE         // Used to adjust (lower) volume for optional headphone-pcb (refer maxVolumeSpeaker / maxVolumeHeadphone) and to enable stereo (headphones are always stereo, even if mono-playback is enabled via GUI)
	#define BLUETOOTH_ENABLE                // If enabled and bluetooth-mode is active, you can stream to your ESPuino or to a headset via bluetooth (a2dp-sink & a2dp-source). Note: This feature consumes a lot of resources and the available flash/ram might not be sufficient.
	//#define SD_MMC_1BIT_MODE              // run SD card in SD-MMC 1Bit mode (using GPIOs 15 + 14 + 2 is mandatory!)
	//#define NO_SDCARD                     // enable to start without any SD card, e.g. for a webplayer only. SD card Settings above will be ignored
	// Runtime RFID reader selection is now supported via web interface
	// Runtime RFID reader type configuration
	// 0 = Auto-detect
	// 1 = MFRC522 (SPI)
	// 2 = MFRC522 (I2C)
	// 3 = PN5180
	#define RFID_READER_TYPE_RUNTIME 0    // Default to Auto-detect
	#if defined(RFID_READER_TYPE_RUNTIME)
	#ifdef PORT_EXPANDER_ENABLE
		0: NEXT_BUTTON
		1: PREVIOUS_BUTTON
		2: PAUSEPLAY_BUTTON
		3: ROTARYENCODER_BUTTON
		4: BUTTON_4
		5: BUTTON_5
	Actions:
	#define BUTTON_4_LONG     CMD_VOLUMEUP
	#define BUTTON_5_LONG     CMD_VOLUMEDOWN
	// Rotary gestures: hold the button, turn the encoder. CMD_NOTHING disables the button as a modifier.
	// A modifier button keeps its normal short/long action when it is pressed *without* turning the encoder.
	#define BUTTON_0_ROTARY_CW   CMD_SEEK_FORWARDS   // hold NEXT + turn: seek within the track
	#define BUTTON_0_ROTARY_CCW  CMD_SEEK_BACKWARDS
	#define BUTTON_1_ROTARY_CW   CMD_NOTHING
	#define BUTTON_1_ROTARY_CCW  CMD_NOTHING
	#define BUTTON_2_ROTARY_CW   CMD_BRIGHTNESS_UP   // hold PLAY/PAUSE + turn: LED brightness
	#define BUTTON_2_ROTARY_CCW  CMD_BRIGHTNESS_DOWN
	#define BUTTON_3_ROTARY_CW   CMD_NOTHING         // rotary push: short=play/pause, long=sleep -- left free on purpose
	#define BUTTON_3_ROTARY_CCW  CMD_NOTHING
	#define BUTTON_4_ROTARY_CW   CMD_NOTHING
	#define BUTTON_4_ROTARY_CCW  CMD_NOTHING
	#define BUTTON_5_ROTARY_CW   CMD_NOTHING
	#define BUTTON_5_ROTARY_CCW  CMD_NOTHING
	#define BUTTON_MULTI_01   CMD_NOTHING   //CMD_TOGGLE_WIFI_STATUS (disabled now to prevent children from unwanted WiFi-disable)
	constexpr uint16_t intervalToLongPress = 700;                 // Interval in ms to distinguish between short and long press of buttons
	// Automatic restart
	// FTP
	// timezone
	// see list of valid timezones: https://github.com/nayarsystems/posix_tz_db/blob/93447c0ddac304ca6672a5fd905261c7e8905159/zones.csv
	// example for Europe/Berlin:	"CET-1CEST,M3.5.0,M10.5.0/3"
	// example for America/Toronto:	"EST5EDT,M3.2.0,M11.1.0"
	// Bluetooth
	constexpr const char nameBluetoothSinkDevice[] = "ESPuino";        // Name of your ESPuino as Bluetooth-device
	// (optinal) Neopixel
	#ifdef NEOPIXEL_ENABLE
		#define CHIPSET					WS2812B     	// type of Neopixel
		#define COLOR_ORDER				GRB
		constexpr float s_warningLowVoltage = 3.0;                      // If battery-voltage is <= this value, a cyclic warning will be indicated by Neopixel (can be changed via GUI!)
		constexpr float s_warningCriticalVoltage = 2.9;                 // If battery-voltage is <= this value, assume battery near-empty. Whether this triggers a shutdown is a separate GUI-toggle (off by default).
		constexpr float s_voltageIndicatorLow = 2.9;                    // Lower range for Neopixel-voltage-indication (0 leds) (can be changed via GUI!)
		constexpr float s_voltageIndicatorHigh = 3.3;                   // Upper range for Neopixel-voltage-indication (all leds) (can be changed via GUI!)
	// enable I2C if necessary
	#if defined(RFID_READER_TYPE_RUNTIME) || defined(PORT_EXPANDER_ENABLE)
		#define I2C_2_ENABLE
	// Topics for MQTT: used to build actual topics in webinterface. So normally there's no need to apply any changes here
	// MQTT configuration available via webinterface: https://forum.espuino.de/t/dokumentation-webinterface/2807.
	#ifdef MQTT_ENABLE
		constexpr const char base_topic[] = "";
		constexpr const char device_id[] = "ESPuino-<MAC>";        // Name that is used for MQTT
		constexpr const char setter_token[] = "set";        		// Word to identify command-topics
		// Topics (settable)
		constexpr const char topicSleep[] = "sleep";           // Cmnd/State: power off (Cmnd '0' or 'OFF' to shutdown), State: ON/OFF
		constexpr const char topicRfid[] = "rfid";            // Cmnd/State: emulate an RFID tag (Cmnd: 12-digit id), State: current RFID tag id
		constexpr const char topicTrackControl[] = "trackcontrol"; // Cmnd: playback control (1=stop,3=play/pause,4=next,5=prev,6=first,7=last,8=next folder,9=prev folder)
		constexpr const char topicLoudness[] = "loudness";    // Cmnd/State: set / report volume (numeric)
		constexpr const char topicSleepTimer[] = "sleep_timer"; // Cmnd/State: sleep timer commands (EOP/EOT/EO5T, minutes, or 0 to deactivate)
		constexpr const char topicSleepTimerState[] = "sleep_timer_state"; // State: JSON {mode,remainingMinutes,remainingTracks}; mode = OFF/MINUTES/EOT/EOP/EO5T
		constexpr const char topicLockControls[] ="lock_controls"; // Cmnd/State: lock or unlock physical controls (ON/OFF)
		constexpr const char topicRepeatMode[] = "repeatmode"; // Cmnd/State: set repeat mode (0=no,1=track,2=playlist,3=both)
		constexpr const char topicLedBrightness[] = "led_brightness"; // Cmnd/State: set LED brightness 0..255
		constexpr const char topicAmbientLight[] = "ambient_light"; // Cmnd/State: set ambient light (ON/OFF)
		// Topics (state only)
		constexpr const char topicTrack[] = "track";          // State: current track info (e.g. "(2/10) /mp3/.../file.mp3")
		constexpr const char topicCoverChanged[] = "cover_changed"; // State: indicates cover image may have changed
		constexpr const char topicState[] = "state";         // State: 'Online' when powering on, 'Offline' when powering off
		constexpr const char topicCurrentIPv4IP[] = "ipv4";  // State: sends current IPv4 address
		constexpr const char topicPausePlay[] = "pauseplay"; // State: playback state: 'idle', 'play', 'pause'
		constexpr const char topicPlaymode[] = "playmode";  // State: numeric playmode
		constexpr const char topicWiFiRssi[] = "wifi_rssi"; // State: WiFi signal strength (dBm)
		constexpr const char topicSRevision[] = "software_revision"; // State: software revision string
		#ifdef BATTERY_MEASURE_ENABLE
		constexpr const char topicBatteryVoltage[] = "battery_voltage"; // State: battery voltage float (e.g. 3.81)
		constexpr const char topicBatterySOC[]     = "battery_soc"; // State: battery charge percent (e.g. 83.0)
	#if (HAL == 4)
	#elif (HAL == 5)
	#elif (HAL == 6)
	#elif (HAL == 7)
	#elif (HAL == 99)
	#endif //settings_override
// clang-format off
#ifndef __ESPUINO_SETTINGS_LOLIN_D32_PRO_H__
#define __ESPUINO_SETTINGS_LOLIN_D32_PRO_H__
    /* This is a develboard-specific config-file for *Wemos Lolin32*. Specific doesn't mean it's only working with this board.
    Lolin32 is the predecessor of Lolin D32.
    PCB: None so far
    Schematics: https://www.wemos.cc/en/latest/_static/files/sch_d32_pro_v2.0.0.pdf
    Caveats: GPIO35 (battery monitoring) + SD can't be changed, it's built in (and because of the SD-pinout used, it is not compatible with MMC-mode)
    Status:
        tested with 2xSPI: RC522 & SD (by biologist79)
    #ifdef SD_MMC_1BIT_MODE
        // NOT SUPPORTED BY D32 pro as 15 / 14 / 2 doesn't match D32 pro's SD-pinout
    #else
        // uSD-card-reader (via SPI) => Cannot be changed, it's built in!
        #define SPISD_CS                     4          // GPIO for chip select (SD)
        #ifndef SINGLE_SPI_ENABLE
            #define SPISD_MOSI              23          // GPIO for master out slave in (SD) => not necessary for single-SPI
            #define SPISD_MISO              19          // GPIO for master in slave ou (SD) => not necessary for single-SPI
            #define SPISD_SCK               18          // GPIO for clock-signal (SD) => not necessary for single-SPI
    // RFID (via SPI)
    #define RST_PIN                         99          // Not necessary but has to be set anyway; so let's use a dummy-number
    #define RFID_MOSI                       13          // GPIO for master out slave in (RFID)
    #define RFID_MISO                       15          // GPIO for master in slave out (RFID)
    #define RFID_SCK                        14          // GPIO for clock-signal (RFID)
        #define RFID_IRQ                    39          // PN5180 IRQ PIN (only needed for low power card detection)
    // I2S (DAC)
    #define I2S_DOUT                        25          // Digital out (I2S)
    #define I2S_BCLK                        27          // BCLK (I2S)
    #define I2S_LRC                         26          // LRC (I2S)
    // Rotary encoder
    #ifdef USEROTARY_ENABLE
        //#define REVERSE_ROTARY                        // To reverse encoder's direction; switching CLK / DT in hardware does the same
        #define ROTARYENCODER_CLK           34          // rotary encoder's CLK
        #define ROTARYENCODER_DT            39          // 39 = 'VN'; Info: Lolin D32 pro is using 35 for battery-voltage-monitoring!
    // Amp enable (optional)
    #define GPIO_PA_EN                      22         // To enable amp for loudspeaker (GPIO or port-channel)
    //#define GPIO_HP_EN                      113         // To enable amp for headphones (GPIO or port-channel)
    #define NEXT_BUTTON                     33          // Button 0: GPIO to detect next
    #define PREVIOUS_BUTTON                  2          // Button 1: GPIO to detect previous
    #define PAUSEPLAY_BUTTON                36          // Button 2: GPIO to detect pause/play
    #define ROTARYENCODER_BUTTON            32          // (set to 99 to disable; 0->39 for GPIO; 100->115 for port-expander)
    #define BUTTON_4                        5          // Button 4: unnamed optional button
    #define BUTTON_5                        99          // Button 5: unnamed optional button
    //#define BUTTONS_LED                   114         // Powers the LEDs of the buttons. Make sure the current consumed by the LEDs can be handled by the used GPIO
        #define PE_INTERRUPT_PIN            99          // GPIO that is used to receive interrupts from port-expander
    #ifdef I2C_2_ENABLE
        #define ext_IIC_CLK                 5           // i2c-SCL (clock)
        #define ext_IIC_DATA                2           // i2c-SDA (data)
    #define WAKEUP_BUTTON                   ROTARYENCODER_BUTTON // Defines the button that is used to wake up ESPuino from deepsleep.
    // (optional) Power-control
    #define POWER                           99           // GPIO used to drive transistor-circuit, that switches off peripheral devices while ESP32-deepsleep
    #ifdef POWER
        //#define INVERT_POWER                          // If enabled, use inverted logic for POWER circuit, that means peripherals are turned off by writing HIGH
    // (optional) Neopixel
    #define LED_PIN                         12          // GPIO for Neopixel-signaling
        //#define DETECT_HP_ON_HIGH                       // Per default headphones are supposed to be connected if HT_DETECT is LOW. DETECT_HP_ON_HIGH will change this behaviour to HIGH.
        #define HP_DETECT                   22          // GPIO that detects, if there's a plug in the headphone jack or not
		#define VOLTAGE_READ_PIN	35		        // GPIO used to monitor battery-voltage.
		constexpr float s_offsetVoltage = 0.00;		// DEFAULT ONLY - the correction is configured in the web UI (General -> Battery) and stored in NVS. This value is just the first-boot seed / fallback.
		constexpr uint16_t rdiv1 = 100;		        // Rdiv1 of voltage-divider (kOhms)
		constexpr uint16_t rdiv2 = 100;			    // Rdiv2 of voltage-divider (kOhms) => used to measure voltage via ADC!
		constexpr adc_attenuation_t inputAttenuation = ADC_11db;		// ADC_0db (0.1->0.95V) // ADC_2_5db (0.1->1.25V) // ADC_6db (0.15->1.75V) // ADC_11db (0.14->2.45V)
    // (optional) hallsensor. Make sure the GPIO defined doesn't overlap with existing configuration. Please note: only user-support is provided for this feature.
    #ifdef HALLEFFECT_SENSOR_ENABLE
        #define HallEffectSensor_PIN        99  	// GPIO that is used for hallsensor (ADC); user-support: https://forum.espuino.de/t/magnetische-hockey-tags/1449/35
    #ifdef IR_CONTROL_ENABLE
        #define IRLED_PIN                   99              // GPIO where IR-receiver is connected (only tested with VS1838B)
Usually, when we’re talking about turning rotary encoder’s knob, volume is adjusted. However, there’s a more or less new feature that allows to adjust Neopixel’s brightness if a button is pressed in parallel. Per default this ist play/pause and when I’m right, you assigned this one to rotary encoder’s button. So when pressing down this button + turning the knob, it could lead to that behaviour described. It’s configurable via webinterface.
Answer is simple: if only battery is connected, there’s no 5 V. Lolin D32 pro would need a boost converter in order to enable it. However, even Espuino’s „complete“ doesn’t provide 5 V internally because, as described, it’ll need an additional dc-dc-converter. Neopixel runs with 3,3 V (even if specified to only run at 5 V) without any problems. Regarding your amp your need to test. If it doesn’t work, use MAX98357a (like we do).
Good evening,
After reading my amplifier’s datasheet, I did as you told me. I connected everything to 3.3V, and the ESPUINO boots up fine on battery power. As for the switch issue, after investigating further, I discovered that I needed to add a pull-up resistor to GPIO36. Once the resistor was in place, everything worked perfectly!
I had some fun testing out a few settings on the web interface. ESPUINO is really great software. Congratulations, and thank you for all your hard work and help!
I’m running some tests to see if adding capacitors improves the sound quality, and I’m posting my new wiring diagram here.
The next step for me will be to design the case in 3D, drawing inspiration from the cassette players of my childhood.
Here is the final diagram.
