Moin moin,
kurze Frage, mein Sohn lässt die Karte, weil von TonUino so gewohnt auf der Box liegen.
Jetzt verhält sich unsere Box aber so, dass bei liegengelassener Karte am Ende des Hörspiels das ganze von vorne los geht.
Leider ist das zum schlafen gehen nicht ganz förderlich xD
#define PORT_EXPANDER_ENABLE // When enabled, buttons can be connected via port-expander PCA9555 (https://forum.espuino.de/t/einsatz-des-port-expanders-pca9555/306)
//#define MQTT_ENABLE // Make sure to configure mqtt-server and (optionally) username+pwd
#define FTP_ENABLE // Enables FTP-server; DON'T FORGET TO ACTIVATE AFTER BOOT BY PRESSING PAUSE + NEXT-BUTTONS (IN PARALLEL)!
//#define NEOPIXEL_ENABLE // Don't forget configuration of NUM_LEDS if enabled
//#define STATIC_IP_ENABLE // DEPRECATED: Enables static IP-configuration (change static ip-section accordingly)
#define HEADPHONE_ADJUST_ENABLE // Used to adjust (lower) volume for optional headphone-pcb (refer maxVolumeSpeaker / maxVolumeHeadphone) and to enable stereo (if PLAY_MONO_SPEAKER is set)
#define PLAY_MONO_SPEAKER // If only one speaker is used enabling mono should make sense. Please note: headphones is always stereo (if HEADPHONE_ADJUST_ENABLE is active)
//#define MEASURE_BATTERY_MAX17055 // Enables battery-measurement via external fuel gauge (MAX17055)
//#define SHUTDOWN_ON_BAT_CRITICAL // Whether to turn off on critical battery-level (only used if MEASURE_BATTERY_XXX is active)
#define PLAY_LAST_RFID_AFTER_REBOOT // When restarting ESPuino, the last RFID that was active before, is recalled and played
//#define USE_LAST_VOLUME_AFTER_REBOOT // Remembers the volume used at last shutdown after reboot
//#define USEROTARY_ENABLE // If rotary-encoder is used (don't forget to review WAKEUP_BUTTON if you disable this feature!)
#define BLUETOOTH_ENABLE // If enabled and bluetooth-mode is active, you can stream to your ESPuino or to a headset via bluetooth (a2dp-sink & a2dp-source). Note: This feature consumes a lot of resources and the available flash/ram might not be sufficient.
//#define PAUSE_ON_MIN_VOLUME // When playback is active and volume is changed to zero, playback is paused automatically. Playback is continued if volume reaches 1. (https://forum.espuino.de/t/neues-feature-pausieren-wenn-rfid-karte-entfernt-wurde/541)
#define DONT_ACCEPT_SAME_RFID_TWICE // RFID-reader doesn't accept the same RFID-tag twice in a row (unless it's a modification-card or RFID-tag is unknown in NVS). Flag will be ignored silently if PAUSE_WHEN_RFID_REMOVED is active. (https://forum.espuino.de/t/neues-feature-dont-accept-same-rfid-twice/1247)
#define SAVE_PLAYPOS_BEFORE_SHUTDOWN // When playback is active and mode audiobook was selected, last play-position is saved automatically when shutdown is initiated
//#define HALLEFFECT_SENSOR_ENABLE // Support for hallsensor. For fine-tuning please adjust HallEffectSensor.h Please note: only user-support provided (https://forum.espuino.de/t/magnetische-hockey-tags/1449/35)
#define VOLUMECURVE 0 // 0=square, 1=logarithmic (1 is more flatten at lower volume)
dies ist mein Aktuelles setting.
gleiches verhalten, nur verzögert ergibt sich auch wenn ich
Aktiviere.
Für mich ergibt es aktuell so keinen Sinn, dass es dann die Einstellung der Endlosschleifen gibt wenn ein Ordner so oder so immer von vorne beginnt.
Vllt bin ich blind und mir fehlt noch eine Einstellung
LG
