mini4l mit Wemos D32pro, RC522, 24er Neopixel, kein Drehencoder, 5x Touchsensoren, ein Taster.
Folgende Einstellungen:
settings.h
// clang-format off
#include "Arduino.h"
#include "values.h"
#else
If in doubts (your board is not listed) use HAL 7
!!!Only ESP32 with PSRAM are supported!!!
HAL 4: Wemos Lolin D32 pro => settings-lolin_D32_pro.h
HAL 5: Lilygo T8 (V1.7) => settings-ttgo_t8.h
HAL 6: ESPuino complete => settings-complete.h
HAL 7: Lolin D32 pro SDMMC Port-Expander => settings-lolin_d32_pro_sdmmc_pe.h
HAL 99: custom => settings-custom.h
#ifndef HAL // Will be set by platformio.ini. There's no need to adjust this manually right here
#define HAL 4
// Enforce port expander for some HALs because it's mandatory for those and users constantly forget it. Endless story...
#if (HAL == 6) || (HAL == 7)
#define PORT_EXPANDER_ENABLE
//#define PORT_EXPANDER_ENABLE // When enabled, buttons can be connected via port-expander PCA9555 (https://forum.espuino.de/t/einsatz-des-port-expanders-pca9555/306)
#define MQTT_ENABLE // Make sure to configure mqtt-server and (optionally) username+pwd
//#define FTP_ENABLE // Enables FTP-server; DON'T FORGET TO ACTIVATE AFTER BOOT BY PRESSING PAUSE + NEXT-BUTTONS (IN PARALLEL)!
#define NEOPIXEL_ENABLE // Don't forget configuration of NUM_LEDS if enabled
#define LANGUAGE DE // DE = deutsch; EN = english: FR = french
#define HEADPHONE_ADJUST_ENABLE // Used to adjust (lower) volume for optional headphone-pcb (refer maxVolumeSpeaker / maxVolumeHeadphone) and to enable stereo (headphones are always stereo, even if mono-playback is enabled via GUI)
//#define USEROTARY_ENABLE // If rotary-encoder is used (don't forget to review WAKEUP_BUTTON if you disable this feature!)
#define BLUETOOTH_ENABLE // If enabled and bluetooth-mode is active, you can stream to your ESPuino or to a headset via bluetooth (a2dp-sink & a2dp-source). Note: This feature consumes a lot of resources and the available flash/ram might not be sufficient.
//#define HALLEFFECT_SENSOR_ENABLE // Support for hallsensor. For fine-tuning please adjust HallEffectSensor.h Please note: only user-support provided (https://forum.espuino.de/t/magnetische-hockey-tags/1449/35)
//#define SD_MMC_1BIT_MODE // run SD card in SD-MMC 1Bit mode (using GPIOs 15 + 14 + 2 is mandatory!)
//#define SINGLE_SPI_ENABLE // If only one SPI-instance should be used instead of two (not yet working!)
//#define NO_SDCARD // enable to start without any SD card, e.g. for a webplayer only. SD card Settings above will be ignored
// Runtime RFID reader selection is now supported via web interface
// Runtime RFID reader type configuration
// 0 = Auto-detect
// 1 = MFRC522 (SPI)
// 2 = MFRC522 (I2C)
// 3 = PN5180
#define RFID_READER_TYPE_RUNTIME 0 // Default to Auto-detect
#if defined(RFID_READER_TYPE_RUNTIME)
#define MFRC522_ADDR 0x28 // default I2C-address of MFRC522
#ifdef PORT_EXPANDER_ENABLE
constexpr uint8_t expanderI2cAddress = 0x20; // I2C-address of PCA9555 (0x20 is true if PCA's pins A0+A1+A2 are pulled to GND)
0: NEXT_BUTTON
1: PREVIOUS_BUTTON
2: PAUSEPLAY_BUTTON
3: ROTARYENCODER_BUTTON
4: BUTTON_4
5: BUTTON_5
Actions:
// *****BUTTON***** *****ACTION*****
#define BUTTON_0_SHORT CMD_NEXTTRACK
#define BUTTON_1_SHORT CMD_PREVTRACK
#define BUTTON_2_SHORT CMD_PLAYPAUSE
#define BUTTON_3_SHORT CMD_MEASUREBATTERY
#define BUTTON_4_SHORT CMD_VOLUMEUP
#define BUTTON_5_SHORT CMD_VOLUMEDOWN
#define BUTTON_0_LONG CMD_NOTHING
#define BUTTON_1_LONG CMD_NOTHING
#define BUTTON_2_LONG CMD_PLAYPAUSE
#define BUTTON_3_LONG CMD_SLEEPMODE
#define BUTTON_4_LONG CMD_VOLUMEUP
#define BUTTON_5_LONG CMD_VOLUMEDOWN
// Rotary gestures: hold the button, turn the encoder. CMD_NOTHING disables the button as a modifier.
// A modifier button keeps its normal short/long action when it is pressed *without* turning the encoder.
#define BUTTON_0_ROTARY_CW CMD_SEEK_FORWARDS // hold NEXT + turn: seek within the track
#define BUTTON_0_ROTARY_CCW CMD_SEEK_BACKWARDS
#define BUTTON_1_ROTARY_CW CMD_NOTHING
#define BUTTON_1_ROTARY_CCW CMD_NOTHING
#define BUTTON_2_ROTARY_CW CMD_BRIGHTNESS_UP // hold PLAY/PAUSE + turn: LED brightness
#define BUTTON_2_ROTARY_CCW CMD_BRIGHTNESS_DOWN
#define BUTTON_3_ROTARY_CW CMD_NOTHING // rotary push: short=play/pause, long=sleep -- left free on purpose
#define BUTTON_3_ROTARY_CCW CMD_NOTHING
#define BUTTON_4_ROTARY_CW CMD_NOTHING
#define BUTTON_4_ROTARY_CCW CMD_NOTHING
#define BUTTON_5_ROTARY_CW CMD_NOTHING
#define BUTTON_5_ROTARY_CCW CMD_NOTHING
#define BUTTON_MULTI_01 CMD_TOGGLE_WIFI_STATUS //(disabled now to prevent children from unwanted WiFi-disable)
#define BUTTON_MULTI_02 CMD_NOTHING
#define BUTTON_MULTI_03 CMD_NOTHING
#define BUTTON_MULTI_04 CMD_NOTHING
#define BUTTON_MULTI_05 CMD_NOTHING
#define BUTTON_MULTI_12 CMD_TELL_IP_ADDRESS
#define BUTTON_MULTI_13 CMD_NOTHING
#define BUTTON_MULTI_14 CMD_NOTHING
#define BUTTON_MULTI_15 CMD_NOTHING
#define BUTTON_MULTI_23 CMD_NOTHING
#define BUTTON_MULTI_24 CMD_NOTHING
#define BUTTON_MULTI_25 CMD_NOTHING
#define BUTTON_MULTI_34 CMD_NOTHING
#define BUTTON_MULTI_35 CMD_NOTHING
#define BUTTON_MULTI_45 CMD_NOTHING
#define SERIAL_LOGLEVEL LOGLEVEL_DEBUG // Current loglevel for serial console
constexpr uint8_t buttonDebounceInterval = 50; // Interval in ms to software-debounce buttons
constexpr uint16_t intervalToLongPress = 700; // Interval in ms to distinguish between short and long press of buttons
//#define CONTROLS_LOCKED_BY_DEFAULT // If set the controls are locked at boot
#define INCLUDE_ROTARY_IN_CONTROLS_LOCK // If set the rotary encoder is locked if controls are locked
// Automatic restart
constexpr uint32_t deepsleepTimeAfterBootFails = 20; // Automatic restart takes place if boot was not successful after this period (in seconds)
// FTP
// timezone
// see list of valid timezones: https://github.com/nayarsystems/posix_tz_db/blob/93447c0ddac304ca6672a5fd905261c7e8905159/zones.csv
// example for Europe/Berlin: "CET-1CEST,M3.5.0,M10.5.0/3"
// example for America/Toronto: "EST5EDT,M3.2.0,M11.1.0"
// Bluetooth
constexpr const char nameBluetoothSinkDevice[] = "ESPuino"; // Name of your ESPuino as Bluetooth-device
// (optinal) Neopixel
#ifdef NEOPIXEL_ENABLE
#define CHIPSET WS2812B // type of Neopixel
#define COLOR_ORDER GRB
#define BATTERY_MEASURE_ENABLE // Don't change. Set automatically if any method of battery monitoring is selected.
constexpr float s_warningLowVoltage = 3.0; // If battery-voltage is <= this value, a cyclic warning will be indicated by Neopixel (can be changed via GUI!)
constexpr float s_warningCriticalVoltage = 2.9; // If battery-voltage is <= this value, assume battery near-empty. Whether this triggers a shutdown is a separate GUI-toggle (off by default).
constexpr float s_voltageIndicatorLow = 2.9; // Lower range for Neopixel-voltage-indication (0 leds) (can be changed via GUI!)
constexpr float s_voltageIndicatorHigh = 3.3; // Upper range for Neopixel-voltage-indication (all leds) (can be changed via GUI!)
// enable I2C if necessary
#if defined(RFID_READER_TYPE_RUNTIME) || defined(PORT_EXPANDER_ENABLE)
#define I2C_2_ENABLE
// Seekmode-configuration
constexpr uint8_t jumpOffset = 30; // Offset in seconds to jump for commands CMD_SEEK_FORWARDS / CMD_SEEK_BACKWARDS
#define JUMP_OFFSET_ROTARY 10 // Offset in seconds per encoder-detent when seeking via a rotary gesture. A button press is a
// deliberate act and can afford jumpOffset; a flick of the encoder is many detents at once, so
// reusing jumpOffset there scrubs minutes at a time. Overridable at runtime via NVS "rotSeekStep".
// A macro (not constexpr) so Button/RotaryEncoder can #ifndef-default it for older overrides.
// Topics for MQTT: used to build actual topics in webinterface. So normally there's no need to apply any changes here
// MQTT configuration available via webinterface: https://forum.espuino.de/t/dokumentation-webinterface/2807.
#ifdef MQTT_ENABLE
constexpr const char base_topic[] = "";
constexpr const char device_id[] = "ESPuino-<MAC>"; // Name that is used for MQTT
constexpr const char setter_token[] = "set"; // Word to identify command-topics
// Topics (settable)
constexpr const char topicSleep[] = "sleep"; // Cmnd/State: power off (Cmnd '0' or 'OFF' to shutdown), State: ON/OFF
constexpr const char topicRfid[] = "rfid"; // Cmnd/State: emulate an RFID tag (Cmnd: 12-digit id), State: current RFID tag id
constexpr const char topicTrackControl[] = "trackcontrol"; // Cmnd: playback control (1=stop,3=play/pause,4=next,5=prev,6=first,7=last,8=next folder,9=prev folder)
constexpr const char topicLoudness[] = "loudness"; // Cmnd/State: set / report volume (numeric)
constexpr const char topicSleepTimer[] = "sleep_timer"; // Cmnd/State: sleep timer commands (EOP/EOT/EO5T, minutes, or 0 to deactivate)
constexpr const char topicSleepTimerState[] = "sleep_timer_state"; // State: JSON {mode,remainingMinutes,remainingTracks}; mode = OFF/MINUTES/EOT/EOP/EO5T
constexpr const char topicLockControls[] ="lock_controls"; // Cmnd/State: lock or unlock physical controls (ON/OFF)
constexpr const char topicRepeatMode[] = "repeatmode"; // Cmnd/State: set repeat mode (0=no,1=track,2=playlist,3=both)
constexpr const char topicLedBrightness[] = "led_brightness"; // Cmnd/State: set LED brightness 0..255
constexpr const char topicAmbientLight[] = "ambient_light"; // Cmnd/State: set ambient light (ON/OFF)
// Topics (state only)
constexpr const char topicTrack[] = "track"; // State: current track info (e.g. "(2/10) /mp3/.../file.mp3")
constexpr const char topicCoverChanged[] = "cover_changed"; // State: indicates cover image may have changed
constexpr const char topicState[] = "state"; // State: 'Online' when powering on, 'Offline' when powering off
constexpr const char topicCurrentIPv4IP[] = "ipv4"; // State: sends current IPv4 address
constexpr const char topicPausePlay[] = "pauseplay"; // State: playback state: 'idle', 'play', 'pause'
constexpr const char topicPlaymode[] = "playmode"; // State: numeric playmode
constexpr const char topicWiFiRssi[] = "wifi_rssi"; // State: WiFi signal strength (dBm)
constexpr const char topicSRevision[] = "software_revision"; // State: software revision string
#ifdef BATTERY_MEASURE_ENABLE
constexpr const char topicBatteryVoltage[] = "battery_voltage"; // State: battery voltage float (e.g. 3.81)
constexpr const char topicBatterySOC[] = "battery_soc"; // State: battery charge percent (e.g. 83.0)
#if (HAL == 4)
#include "settings-lolin_d32_pro.h" // Contains all user-relevant settings for Wemos Lolin D32 pro
#elif (HAL == 5)
#include "settings-ttgo_t8.h" // Contains all user-relevant settings for Lilygo TTGO T8 1.7
#elif (HAL == 6)
#include "settings-complete.h" // Contains all user-relevant settings for ESPuino complete
#elif (HAL == 7)
#include "settings-lolin_d32_pro_sdmmc_pe.h" // Pre-configured settings for ESPuino Lolin D32 pro with SDMMC + port-expander (https://forum.espuino.de/t/espuino-minid32pro-lolin-d32-pro-mit-sd-mmc-und-port-expander-smd/866)
#elif (HAL == 99)
#include "settings-custom.h" // Contains all user-relevant settings custom-board
#endif //settings_override
// clang-format off
#ifndef __ESPUINO_SETTINGS_LOLIN_D32_PRO_H__
#define __ESPUINO_SETTINGS_LOLIN_D32_PRO_H__
/* This is a develboard-specific config-file for *Wemos Lolin32*. Specific doesn't mean it's only working with this board.
Lolin32 is the predecessor of Lolin D32.
PCB: None so far
Schematics: https://www.wemos.cc/en/latest/_static/files/sch_d32_pro_v2.0.0.pdf
Caveats: GPIO35 (battery monitoring) + SD can't be changed, it's built in (and because of the SD-pinout used, it is not compatible with MMC-mode)
Status:
tested with 2xSPI: RC522 & SD (by biologist79)
#ifdef SD_MMC_1BIT_MODE
// NOT SUPPORTED BY D32 pro as 15 / 14 / 2 doesn't match D32 pro's SD-pinout
#else
// uSD-card-reader (via SPI) => Cannot be changed, it's built in!
#define SPISD_CS 4 // GPIO for chip select (SD)
#ifndef SINGLE_SPI_ENABLE
#define SPISD_MOSI 23 // GPIO for master out slave in (SD) => not necessary for single-SPI
#define SPISD_MISO 19 // GPIO for master in slave ou (SD) => not necessary for single-SPI
#define SPISD_SCK 18 // GPIO for clock-signal (SD) => not necessary for single-SPI
// RFID (via SPI)
#define RST_PIN 99 // Not necessary but has to be set anyway; so let's use a dummy-number
#define RFID_CS 21 // GPIO for chip select (RFID)
#define RFID_MOSI 13 // GPIO for master out slave in (RFID)
#define RFID_MISO 15 // GPIO for master in slave out (RFID)
#define RFID_SCK 14 // GPIO for clock-signal (RFID)
#define RFID_BUSY 33 // PN5180 BUSY PIN
#define RFID_RST 22 // PN5180 RESET PIN
#define RFID_IRQ 39 // PN5180 IRQ PIN (only needed for low power card detection)
// I2S (DAC)
#define I2S_DOUT 25 // Digital out (I2S)
#define I2S_BCLK 27 // BCLK (I2S)
#define I2S_LRC 26 // LRC (I2S)
// Rotary encoder
#ifdef USEROTARY_ENABLE
//#define REVERSE_ROTARY // To reverse encoder's direction; switching CLK / DT in hardware does the same
#define ROTARYENCODER_CLK 34 // rotary encoder's CLK
#define ROTARYENCODER_DT 39 // 39 = 'VN'; Info: Lolin D32 pro is using 35 for battery-voltage-monitoring!
// Amp enable (optional)
//#define GPIO_PA_EN 112 // To enable amp for loudspeaker (GPIO or port-channel)
//#define GPIO_HP_EN 113 // To enable amp for headphones (GPIO or port-channel)
#define NEXT_BUTTON 33 // Button 0: GPIO to detect next
#define PREVIOUS_BUTTON 2 // Button 1: GPIO to detect previous
#define PAUSEPLAY_BUTTON 36 // Button 2: GPIO to detect pause/play
#define ROTARYENCODER_BUTTON 32 // (set to 99 to disable; 0->39 for GPIO; 100->115 for port-expander)
#define BUTTON_4 39 // Button 4: unnamed optional button
#define BUTTON_5 34 // Button 5: unnamed optional button
//#define BUTTONS_LED 114 // Powers the LEDs of the buttons. Make sure the current consumed by the LEDs can be handled by the used GPIO
#define PE_INTERRUPT_PIN 99 // GPIO that is used to receive interrupts from port-expander
#ifdef I2C_2_ENABLE
#define ext_IIC_CLK 5 // i2c-SCL (clock)
#define ext_IIC_DATA 2 // i2c-SDA (data)
#define WAKEUP_BUTTON ROTARYENCODER_BUTTON // Defines the button that is used to wake up ESPuino from deepsleep.
// (optional) Power-control
#define POWER 5 // GPIO used to drive transistor-circuit, that switches off peripheral devices while ESP32-deepsleep
#ifdef POWER
//#define INVERT_POWER // If enabled, use inverted logic for POWER circuit, that means peripherals are turned off by writing HIGH
// (optional) Neopixel
#define LED_PIN 12 // GPIO for Neopixel-signaling
//#define DETECT_HP_ON_HIGH // Per default headphones are supposed to be connected if HT_DETECT is LOW. DETECT_HP_ON_HIGH will change this behaviour to HIGH.
#define HP_DETECT 22 // GPIO that detects, if there's a plug in the headphone jack or not
#define VOLTAGE_READ_PIN 35 // GPIO used to monitor battery-voltage.
constexpr float s_offsetVoltage = 0.00; // DEFAULT ONLY - the correction is configured in the web UI (General -> Battery) and stored in NVS. This value is just the first-boot seed / fallback.
constexpr uint16_t rdiv1 = 100; // Rdiv1 of voltage-divider (kOhms)
constexpr uint16_t rdiv2 = 100; // Rdiv2 of voltage-divider (kOhms) => used to measure voltage via ADC!
constexpr adc_attenuation_t inputAttenuation = ADC_11db; // ADC_0db (0.1->0.95V) // ADC_2_5db (0.1->1.25V) // ADC_6db (0.15->1.75V) // ADC_11db (0.14->2.45V)
// (optional) hallsensor. Make sure the GPIO defined doesn't overlap with existing configuration. Please note: only user-support is provided for this feature.
#ifdef HALLEFFECT_SENSOR_ENABLE
#define HallEffectSensor_PIN 34 // GPIO that is used for hallsensor (ADC); user-support: https://forum.espuino.de/t/magnetische-hockey-tags/1449/35
#ifdef IR_CONTROL_ENABLE
#define IRLED_PIN 22 // GPIO where IR-receiver is connected (only tested with VS1838B)
#define IR_DEBOUNCE 200 // Interval in ms to wait at least for next signal (not used for actions volume up/down)
#define RC_PLAY 0x68 // command for play
#define RC_PAUSE 0x67 // command for pause
#define RC_NEXT 0x6b // command for next track of playlist
#define RC_PREVIOUS 0x6a // command for previous track of playlist
#define RC_FIRST 0x6c // command for first track of playlist
#define RC_LAST 0x6d // command for last track of playlist
#define RC_VOL_UP 0x1a // Command for volume up (one step)
#define RC_VOL_DOWN 0x1b // Command for volume down (one step)
#define RC_MUTE 0x1c // Command to mute ESPuino
#define RC_SHUTDOWN 0x2a // Command for deepsleep
#define RC_BLUETOOTH 0x72 // Command to enable/disable bluetooth
#define RC_FTP 0x65 // Command to enable FTP-server
led.h
#pragma once
typedef enum class LedIndicator {
BootComplete = 0,
Error,
Ok,
PlaylistProgress,
Rewind,
Voltage,
VoltageWarning,
VolumeChange
} LedIndicatorType;
// ordered by priority
enum class LedAnimationType {
Boot = 0,
Shutdown,
Error,
Ok,
VoltageWarning,
Download, // MediaHub file sync (concept §12): outranks normal playback feedback, since it runs before playback even starts
Volume,
BatteryMeasurement,
Rewind,
Playlist,
Speech,
Pause,
Progress,
Webstream,
Idle,
Busy,
NoNewAnimation
enum class LedPlaylistProgressStates {
FillBar = 0,
Wait,
EmptyBar,
EmptyBarToTarget,
Done
struct AnimationReturnType {
bool animationActive;
int32_t animationDelay;
bool animationRefresh;
void clear() {
animationActive = false;
animationDelay = 0;
AnimationReturnType()
: animationActive(false)
, animationDelay(0)
, animationRefresh(false) { }
AnimationReturnType(bool active, int32_t delay, bool refresh = false)
: animationActive(active)
, animationDelay(delay)
, animationRefresh(refresh) { }
// Step and floor for the CMD_BRIGHTNESS_UP/DOWN command. Defined unconditionally (not under
// NEOPIXEL_ENABLE) because Cmd.cpp dispatches that command regardless of whether LEDs are compiled in
// -- Led_SetBrightness()/Led_GetBrightness() are always defined and simply no-op without NEOPIXEL, so
// referencing these constants there must compile too. See issue #453.
#define LED_BRIGHTNESS_STEP 4u // Brightness change per rotary detent (CMD_BRIGHTNESS_UP/DOWN)
#define LED_BRIGHTNESS_MIN 1u // Never let a gesture turn the LEDs fully off -- that looks like a crash
#define LED_INITIAL_BRIGHTNESS 16u
#define LED_INITIAL_NIGHT_BRIGHTNESS 2u
// FastLED's clockless-SPI backend claims SPI2_HOST (== Arduino's HSPI) via its own private
// bookkeeping, which knows nothing about hosts Arduino already took. That only works out while the
// SD card stays off HSPI, i.e. in SD-MMC mode. With SPI-SD, SdCard.cpp's spiSD(HSPI) and FastLED
// end up driving the same peripheral concurrently -- an SPI HAL assert plus LED-refresh timeouts,
// i.e. a reboot loop (forum #4758). Leaving the macro undefined falls back to the RMT driver.
#define FASTLED_ESP32_USE_CLOCKLESS_SPI 1
#include <FastLED.h>
struct LedSettings {
uint8_t numIndicatorLeds = 24;
uint8_t numControlLeds = 0;
std::vector<uint32_t> controlLedColors;
uint8_t numIdleDots = 4;
bool offsetLedPause = false;
int16_t progressHueStart = 85;
int16_t progressHueEnd = -1;
int16_t atmoHue = 10;
int16_t atmoSaturation = 180;
uint8_t dimmableStates = 50;
bool neopixelReverseRotation;
uint8_t ledOffset;
bool Led_Pause = false; // Used to pause Neopixel-signalisation (while NVS-writes as this leads to exceptions; don't know why)
bool Led_NightMode = false;
bool Led_AmbientLight = false;
uint8_t Led_InitialBrightness = LED_INITIAL_BRIGHTNESS;
uint8_t Led_Brightness = LED_INITIAL_BRIGHTNESS;
uint8_t Led_NightBrightness = LED_INITIAL_NIGHT_BRIGHTNESS;
uint8_t Led_AmbientBrightness = LED_INITIAL_BRIGHTNESS;
void Led_Init(void);
void Led_Exit(void);
void Led_Indicate(LedIndicatorType value);
void Led_SetPause(boolean value);
void Led_ResetToInitialBrightness(void);
void Led_ResetToNightBrightness(void);
uint8_t Led_GetBrightness(void);
void Led_SetBrightness(uint8_t value);
void Led_TaskPause(void);
void Led_TaskResume(void);
void Led_ShowOtaProgress(uint8_t percent);
void Led_SetDownloadProgress(bool active, uint8_t percent = 0);
void Led_SetNightmode(bool enabled);
bool Led_GetNightmode();
void Led_ToggleNightmode();
void Led_SetAmbientLight(bool enabled);
bool Led_GetAmbientLight();
void Led_ToggleAmbientLight();
